Good day all bro canon...I had a canon Ir2525 come out a massage 'insert the drum' i try to change drum(original) HVT board,Dc controller still the sae massage...can anyone out there had this problem before?pls help
Ir2525 (insert the drum)
Re: Ir2525 (insert the drum)
Drum contact must > contact frame interior contact**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Yes i did saw the metal plate of the drum touch the spring contact!!i just upgare the DC con Boot and Boot lang using user support tool still the same problem ..i want to try the Dc controller PCB but can't find..any ideaComment
also look for any small packing material on drum end
The machine constantly displays an "insert drum" message.
Check >The spring contact that goes from the HVT end block to the drum >make sure it is not out of place and not making contact.
Re position the contact. Please see the photo below.
1-The message "Insert Drum" is on the display, however, the drum is correctly inserted in the machine.
2-The drum unit had been replaced and the high voltage contacts were clean and not deformed in any way.
3-An "All Clear" was performed as well to no avail.
Workaround :
Replacing the H.V.T. resolved the issue.
FM1-H933-000 iR2525/2530Last edited by teckat; 05-16-2018, 03:31 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Workaround :
FM1-H933-000 iR2525/2530Comment
Originally posted by githenhiĐang cần gấp
________________
hạt giống hoa súng
DMCA Content Protection Service - Protect Your Content
Stupidity Doing Same Thing Over Button (0681).jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Good day all bro ...I had a canon Ir2525 come out a massage 'insert the drum' i try to change drum(original) HVT board,Dc controller still the sae massage...can anyone out there had this problem before?pls helpComment
I had the same problem too. I made an appointment with (HVT) and it went well. good luck. Also check the lines going to the DC controller. good luckComment
