Canon Y-1 finisher with Buffer Pass Unit E2 with broken paper jam sensor actuator
  • axyun
    • Aug 2007
    • 1323
    Customer with buffer pass unit E2. Has 2 identical actuators. One is broken and I have been unable to get part number. Please help if you have PC. I just have for the machine IRC2880. Frank
  • 20 year tech
    • May 2014
    • 577
    Re: Canon Y-1 finisher with Buffer Pass Unit E2 with broken paper jam sensor actuator
    I believe you are looking for #19 flag sensor FC5-1048bp part.pdf
    • axyun
      • Aug 2007
      • 1323
      Thank you Chris. When I googled the part number to make sure then all of a sudden I got the E2 parts manual which shows the 2 identical actuators with the part # you provide.
      In the meantime I found the piece that broke off and glued it and it has been holding. If I have a problem I now have the part number thanks to you. Hope you are having a good day. Frank
