Canon i-SENSYS MF732Cdw non origianl toner notification
  • Elmo
    • Feb 2010
    • 541
    Hi all
    Does anyone know if it is possible to turn off the non original toner notificatioin
    on Canon i-SENSYS MF732Cdw
    I Used To Live To Fix Things Now i Fix Things To Live
  • teckat
    • 16092
    Re: Canon i-SENSYS MF732Cdw non origianl toner notification
    Originally posted by Elmo
    Hi all
    under Printer server properties >> look for a menu item to check or un-check
    example
    • Elmo
      • Feb 2010
      • 541
      Thank you for the reply
      i was looking hoping there was an option turn it off at the machine
      so it does not show in the machine display
      • teckat
        • 16092
        under Display Settings
        Display Timing for Cart. Prep
        <Auto>
        <Off>-----------set to OFF ??
        <Custom>
        <On>
        The first thing you can do is remove the cartridge and try re-inserting it to see if the printer will recognize it, if it still not recognize the cartridge then simply hold down the stop button (this is the button with the triangle inside a circle) for 5 seconds. This will disable the printer’s cartridge recognition facility and you should be able to print happily without any further interruption
