iRC2550i (like 3080) series E003 and E009
  • callmeozzy@hotmail.com
    • Jul 2025
    Hi Guys,
    Ive got an iRC2550) that is showing E003 and occasionally E009. I have tried replacing the Fixing Assy but that doesn't fix it. I reloaded the system software and also did a DC cear prior to that. Basically the paper picks up and usually doesn't reach the registration roller then joes straight into error. It has got me stumped so i am hoping one of you blokes might be able to help me
    Andy
  • kwazimoto
    • Jan 2007
    • 199
    E003
    Did some looking and here is what I found hope it helps E003-002 shutter below the drum cart came off part num fc6-9393 and as far as the E009 PS 13 fixing pressure home sensor has been bad ..
      • Jul 2025
      Thanks for your input Kwazimoto. I decided to try a DC Driver PCB as that provides the signal to the Fuser and Fixing Drive Assy. Good move as it fixed the problem,
      Cheers Andy
