Canon IR Adv 5030i suddenly stop responding with ip.
  • Service@PRT
    • Oct 2016
    • 181
    Hi guys,
    We have a customer that suddenly their canon ir adv 5030i suddenly stop getting print print job and scan to folder not working. I tried to do some basic networking things like pinging.. making machine dhcp... Getting into web ui... But to no avail. When you connect the lan cable to machine and router both are have lights. But the ip of the machine is not configuring. Just want to ask your insight and i just want to confirm if its really the board have the problem. Before its working good. Just so sudden.
    Hoping for your response.
    Thank you.
    Sent from my HUAWEI VNS-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • roho
    • Mar 2009
    • 844
    Re: Canon IR Adv 5030i suddenly stop responding with ip.
    I would consider a MMI clear, I have had many odd issues like this, a MMI clear may fix this after rebooting and inputting network settings.
    • JPiek
      • Oct 2014
      • 435
      Have you tried booting the machine with 1&7 key pressed ? It should get a fixed IP adress 172.16.1.100
      You could then give your laptop IP 172.16.1.1, connect it 1-on-1 with the canon and see if you can ping the machine then...
      If that works the networkcard is alright...
      Johan
      • Service@PRT
        • Oct 2016
        • 181
        Yeah tried that one already. But same problem.
        • Service@PRT
          • Oct 2016
          • 181
          Will try that one when i go back to the client..
