8205 Light Image
  • roho
    • Mar 2009
    • 844
    [Misc] 8205 Light Image
    Hello everyone.
    The first sorry for my English.
    I have a problem with an Ira-adv8585 machine.
    The problem is only as a printer, not as a copier.
    The problem is that sometimes it prints little intensity (not always and only with some files, these files have been tested in another machine equal and go well)
    As a copier, she has never had a problem.
    It is the same to print in postcription, VFR or direct printing on a pendrive.
    We have increased the level of intensity as a printer at the user level but sometimes the quality is not good.
    As it does not always happen, we thought there was a temperature problem in the client since in winter there are only between 12 and 16 degrees but now the temperature is normal and still bad.
    Thanks for everything.
    Greetings.
    Run some PG prints and check for density. The dev unit can get contaminated with dust. I believe a PG 2 or 3 gives gradations across the page.
