iRAC7260 with random error codes when switched on.
  • vwbay72
    • May 2018
    • 14
    [Error Code] iRAC7260 with random error codes when switched on.
    Hi,
    I have a irac7260 which is throwing up different error codes when switched on (E075,E022,E023,E815 etc) the ITB is central and no blocked waste toner, im beginning to think its a 24V dc power supply. anyone had this or know what is causing this?
  • roho
    • Mar 2009
    • 844
    Re: iRAC7260 with random error codes when switched on.
    Had something similar, but different codes were being generated. In my case it was the riser pcb. Start checking voltages, starting with 24 dc and hopefully you can trace it.
    • vwbay72
      • May 2018
      • 14
      Thanks Roho, i was wondering if it could be the riser PCB, i will check that out.
      Cheers
      • vwbay72
        • May 2018
        • 14
        Hi,
        I have resolved this by fitting a 24V DC power supply.
