IRA C5235 usb ports.
  • Desert Rat
    • May 2008
    • 1089
    I noticed two usb ports on this machine where a USB drive could be plugged into. I see in the book the one on the control panel is for
    firmware downloads. The one on the back panel by the network connector, is that one used to print files from?
    I thought there was a way to print from a USB drive connected to that port?
    I looked through the manual but did not find any info about that port.
    Is this a feature that needs to be installed? Or how can I tell if it is installed and the customer just
    did not know how to use it?
    DR
  • teckat
    • 16092
    Re: IRA C5235 usb ports.
    • Desert Rat
      • May 2008
      • 1089
      Thanks Teckat, my customer tells me he tried using a video from utube. I will give this one a try.
      Thanks again
      DR
      • JPiek
        • Oct 2014
        • 435
        I found this note-to-self somewhere... I could swear it's from this forum (Hi Teckat )
        You need to enable the USB port as follows:
        1. Select Settings/Registration (login as an administrator) > Preferences > External Interface > USB Settings, set Use USB Device to "On" and Use MEAP Driver for USB Input Device to "Off".
        2. Select Settings/Registration (login as an administrator) > Preferences > Display Settings > Store location Display Settings > Memory Media, and set "On".
        3. Select Settings/Registration > Function Settings > Store/Access Files > Memory Media Settings > Use Scan/Print function, set Use Scan Function and Use Print Function to "On"
        Service level 2 ,DSPLY-SW ,UI-MEM set to 1.Think it will only work if you have ps print kit installed
        Johan
        • teckat
          • 16092
          Thanks again
          DR
          c5200 series
          Network
          Standard
          = Ethernet 1000Base-T/100Base-TX/10Base-T
          Optional
          = Wireless LAN w/Wireless LAN Kit
          To store scanned data in a storage location, you must specify
          the following settings:
          Mail Box
          [Store Location Display Settings]
          <Mail Box>: [On]
          Advanced Box
          <Advanced Box/Network>: [On]
          Network
          Server Settings
          [Open to Public]: [By SMB]
          [SMB Server Settings]
          <Use SMB Server>: [On]
          [Server Name]: SERVER
          Client Settings
          [Network Place Settings]
          [Name]: images
          <Protocol>: [SMB]
          [Location]: \\192.168.1.23\share
          [Protocol for External Reference]
          <SMB>: [On]
          Memory Media
          <Memory Media>: [On]
          [Use MEAP Driver for External USB Device]: [Off ]
          If the imagePASS or ColorPASS is attached to the machine, you cannot open the Advanced Box of the machine externally
          as an SMB server. Set to open as a WebDAV server on the network. For information on the settings, see e-Manual > Security.
          You can set a name and PIN for [Mail Box], as necessary. For information on the settings, see e-Manual > Security.
          Using Memory Media
          To use memory media, specify Store Location Display
          Settings and the USB settings.
          12 Press [Preferences].
          3 Press [External Interface].
          4 Press [USB Settings].
          5 Press [Use MEAP Driver for External USB Device].
          6 Press [Off] → [OK].
          7 Press [Close].
          8 Turn OFF the main power of the machine, and then turn ON the main power again.
          power OFF, and then ON.
          • Desert Rat
            • May 2008
            • 1089
            Teckat and Jpiek,
            Thank you for all that information. I will be seeing this machine today just for this concern.
            Thanks again for all the settings info, I will apply it to the machine today.
            How can I tell if the PS print kit is installed?
            DR
            • teckat
              • 16092
              Teckat and Jpiek,
              DR
              press counter check--should show there
              • Desert Rat
                • May 2008
                • 1089
                I did not see anything about a PS kit under counter. But I followed the instructions and got it to work.
                Thanks a bunch
                DR
