Trouble with Canon IR 3570
  • Legarad
    • Jul 2025
    The back door is not opening and there is a jam in that door. And the lower door on that side came out. What can be done?
  • dan7777
    • Dec 2012
    • 680
    Re: Trouble with Canon IR 3570
    You can try and remove the cover over the hinges and take the right door off. You have to separate the upper and lower. Best to have a service manual to show you how to do it if you have never done it before. Most likely the transfer/registration section is catching on something. You may get lucky and it may work after you get done but may have something bent. Those are old machines and someone may sell you a used right door.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      To prevent the right Door Assembly from being locked, the shape of Wire Hook is changed.
      Use long screwdriver and push the hook to inside.
      HOOK HOLDER UNIT
      Old FM2-0355-000
      New FM2-0355-010
