ir7086 / ir7095 new DC controller?
  • jiongpao
    • May 2009
    • 413
    I saw somewhere since long ago in this thread about the replacement of new version or new batch of ir7086/7095 DC controller that solved negative or light print out? with images differentiate between the old and new correction of DC controller.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: ir7086 / ir7095 new DC controller?
    I don't know about conntroller but i found this bulletin for light image/E110 error/mirror image.
    Subject:
    Measures against the fault in the Laser Scanner Assembly (light image/E110 error/mirror image)
    Detail:
    Fault in the laser diode of the laser scanner assembly may cause poor density of image, E110 (The laser scannermotor rotation has a fault.), or mirror image.
    For servicing, the setting of the laser assembly is newly made.
    Servicing Work:If the above symptom occurs, replace it with the laser assembly newly set.
    Old FM2-5449-020 LASER SCANNER ASSEMBLY
    New FM2-8146-000 LASER ASSEMBLY
