4551 Network settings
  • repeatcopiers
    • Sep 2008
    • 591
    I just purchased an Adv4551i for a customer and when I select Preference>Network> the only thing I can highlight is Output Report. On the older Advances, I usually go under service mode and clear password and this will let me highlight Confirm Network Conn...... so that I can go into the IP address settings. Is there something different about this new model?
  • teckat
    • 16076
    Re: 4551 Network settings
    Log in as an administrator, otherwise important items regarding the network and security cannot be set. To set up the user management after the setup is complete, you need to log in as an administrator. The default user name for the administrator is "Administrator" and the default password is "7654321". When operating as "Administrator," make sure to change the password in order to improve security. The changed password should be known by the administrator only.
    Initializing the administrator password
    If you have forgotten the password for "Administrator," it can be returned to the default password. Press the [Counter/Device Information] key <Device Info./Other> <Initialize Admin. Password> enter the license key press <Start>
    If you have forgotten the password for "Administrator," it can be returned to the default password. Press the [Counter/Device Information] key <Device Info./Other> <Initialize Admin. Password> enter the license key press <Start> <OK>.
    If "Administrator" is disabled, it is enabled when initializing the password.(Registering User Information in the Local Device)
    You can prohibit initialization of the administrator password. <Prohibit Initialization of Administrator Password>
    • repeatcopiers
      • Sep 2008
      • 591
      Thank you, got it!
      • teckat
        • 16076
        Originally posted by repeatcopiers
        Thank you, got it!
        Welcome👌
