Ir3235 restart it self
  • kstan268
    • Apr 2012
    • 85
    Dear,
    I have a problem with copier Canon iR3225N.
    Precisely problem with boot-ing. When I start machine
    status about loading is shown in screen without logo of
    Canon, without name Canon and without Wait... message.
    Status loading is only few mm (blue status) and it stops.
    After about one min machine restarts itself and it goes
    same procedure (few mm blue status and it stops and
    after about one min restart.....)
    I've tried to change HDD with good one and nothing.
    I've tried to change memory with good one and nothing.
    I've tried to enter into download mode (safe mode and
    normal mode and nothing,copier stops)
    Copier has no more than 15k copies.
    Does anyone have any ideas/solutions what it could be
    or what else I can try. I'll be very glad to hear yours
    opinion.I had also change a main controller but it work only for 1 to 2 houer then come back again
    Thank you and best regards!
  • IndoCE
    • Nov 2014
    • 14
    Re: Ir3235 restart it self
    Sound like 3way unit ( upper right door ) problem , no power or short circuit
    • COPIERTEC ASSOCIATES
      • Aug 2011
      • 279
      Originally posted by kstan268
      Dear,
      Have you tried to measure wall voltage ie voltage from the socket to specified voltage?
      If so what are the output voltages you get to the DC board;you should get 24v,12v,5v and 3.5v to be able to boot the machine.
