Canon IR Advance C5035 print quality
  • Reed
    • Feb 2011
    • 261
    Recently changed all the drums on this machine (used compatible and possibly regretting it now) Now the machine is printing color streaks/splash intermittently. Originally it was just a blue splash/streak but I went out and swapped places with the magenta and cyan drums to see if the problem followed the drum. It is still doing the same thing but now its showing some magenta. I have attached a couple images of what it is doing. Thanks in advance
  • roho
    • Mar 2009
    • 844
    Re: Canon IR Advance C5035 print quality
    Don't see the attachments and from your description likely don't need to. Try real OEM new drums and your problems are solved.
    • techandtrader
      • Jun 2016
      • 335
      Some of those streaks can be deceiving esp when the cleaning blade is starting to fail. I would replace the cleaning assembly first. Esp if it is not the updated newest version. FM4-7244-020 Two revisions on this part. I have had decent results with comp drums on these lower speed models. They are forbidden in the high speeds. Don't forget to run DPC.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
      • Reed
        • Feb 2011
        • 261
        I have ordered new drums Here are a couple samples of the print quality. Like I mentioned. It wasn't doing this until I replaced the drums which were compatible Hopefully the images show up this time canon image.pdfcanon image 1.pdf
        • vwbay72
          • May 2018
          • 14
          Hi,
          I would check that the ITB is being cleaned, if there are streaks then replace the ITB cleaner assembly FM4-7244-010.
          • vwbay72
            • May 2018
            • 14
            Just seen the examles, Genuine Canon drum units will fix this.
