Canon IR 3235 E 804-0004
  • doktor
    • 214
    [Error Code] Canon IR 3235 E 804-0004
    Hello;
    I need help.The machine shows the code E 804-0004.I've already changed Main Controller Fan even though he was running normally when turning on machine,and MAIN POWER SUPPLY PCB ASSEMBLY with fan,when turning on fan running normally.
    Any help is welcome.Thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: Canon IR 3235 E 804-0004
    Hi Doc!
    Main controller?
    • teckat
      • 16083
      Check you supply voltage at wall outlet
      Hot > Ground = ?
      Hot> Neutral = ?
      Neutral> Ground = +/- 0.0 to 0.5 v max
      Fan lock signal. -- DC PCB issue !
      • luis1984bol
        • Nov 2011
        • 143
        What version firmware does the machine have?
        Try using version V47.01
        It worked for me!!!
        • hood4472
          • Aug 2013
          • 17
          It might be a good idea to check all of your fans. I've seen the wrong fan indicated by error code in the past. Good luck.
