Canon IR 3235 with an E804-0001
  • kuby
    • Oct 2007
    • 1409
    Tech has replaced thepower supply cooling fan and the DC Control Board and the error stillpersist. Is there anything else that could be causing the issue. Says he can not start the machine to see which firmware it on the machine so I do not know.
  • pramod
    • Jul 2010
    • 21
    Re: Canon IR 3235 with an E804-0001
    Have you checked cooling fan near main processor board .
    Sent from my SM-G610F using Tapatalk
    • teckat
      • 16083
      E804-0001
      is power supply cooling fan is FM3----Cools the 12V/24V power supply.
      Power supply cooling fan (FM3) drives at full-speed at paper feed and at 1/2 speed in other situations.----24V or 12V
      connections
      DCON: J304
      Relay PCB:
      J546, J533
      FM3 gets signal from RELAY-------check or replace Relay PCB (FM3-5050-000) ----might output DC fan signals ?--------------------
      Relay PCB Provides DC power supply for the main controller PCB, reader controller PCB, DC controller PCB, Super G3 FAX board, 2-cassette pedestal, and 3 Way Uni
      • kuby
        • Oct 2007
        • 1409
        Thanks will try that.
