Ipr6010c not showing ipv4 settings in system settings
  • mc921
    • Oct 2015
    • 23
    We just purchased a used 6010c without a rip. We had a used 1200 server to hookup, but the systems manger in the 6010 does not show anything other than proxy settings. Is there a setting somewhere to turn on the ipv4 settings? Thank you.
  • mc921
    • Oct 2015
    • 23
    Re: Ipr6010c not showing ipv4 settings in system settings
    Additional info: the printer was setup for an oce prismatic rip. I'm not sure of the procedure to change the setup for the a1200 server.
    • roho
      • Mar 2009
      • 844
      Service mode: copier>option>interface>image cont: set to 0 and reboot. That should tell the device that it does not have a RIP and should restore the networking settings on the device.
      • mc921
        • Oct 2015
        • 23
        Thanks...but that was the first thing I tried. I think I need to set the subnet mask and gateway...but those options are gone.
        • roho
          • Mar 2009
          • 844
          Try a MMI or Main Con clear.
          • mc921
            • Oct 2015
            • 23
            Haven't tried that...i will give it a shot.
            • mc921
              • Oct 2015
              • 23
              Ok...got it connect...but now says to check power and video cables....
