line on copy
  • DONVAN
    line on copy
    i have a light color line on 11x17 copy some time 2 inch wide
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    What model is the machine?
    Does it happen when printing or when using the reader?
    Too many variables and not enough information
    • DONVAN
      line on copy is 2 inches wide its transparent,looks like a roller line
      the machine is a canon c3200 it happens when printing
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Not a colored line?
        It's either the fuser...or an issue with the itb assembly.
        If you're a customer rather than a tech...it's time to fork out and have a tech look at the machine.
        I KNOW it means you'll actually have to pay around $150 for the service call...but you need a tech to look at the machine to confirm the part causing the issue.
        A tech will do a series of single color shots to test each of the drums...iRC3200 drums have had issues recently where a waxy build up leaves a light band through images.
        Also...the tech will check the jam history to see if there's any jam codes associated with the issue....cassette rollers will cause retry jams...fuser will cause stationary jams.
        I understand that you are not a tech...but we're not getting enough info to help you...time to book a service call.
        • 10871087
          • Jan 2005
          • 1143
          Call a tech
