Canon Linux driver not working
  • AnotherBigAl
    • 34
    [Misc] Canon Linux driver not working
    We have a Canon LPB7680Cx laser printer and a Canon C5030i all-in-one copier/printer/scanner. According to the Canon website at
    Code:
    [URL="https://www.canon.co.uk/support/products/imagerunner/imagerunner-advance-c5030i.aspx?type=drivers&language=&os=Linux%20(64-bit"]imageRUNNER ADVANCE C5030i - Support - Download drivers, software and manuals - Canon UK[/URL]
    both use the
    Code:
    UFR II/UFRII LT Printer Driver for Linux V3.50
    driver on our 64 bit Linux Mint 18.3 Cinnamon computer. Up to a point this is true. Once that driver is installed the Laser printer works fine but the colour output on the copier is atrocious and not usable. Furthermore I cannot get the stapler to staple or the scanner to scan. Output is fine using it as a photocopier, and it will staple where I want it is just running it from a computer where there is a problem.
    If, from the computer, I select the printer options and print a test page that prints properly. However, if I select to print a ‘self test’ page the output says, and I quote, “If you can read this, you are using the wrong driver for your printer.”
    Can anyone suggest what to do to get our printer working properly please?
    • 22808
    Re: Canon Linux driver not working
    Code:
    both use the
    Code:
      • 22808
      this is a CONNECTIVITY issue please post in the proper forum.
      • AnotherBigAl
        • 34
        Code:
        https://www.canon.co.uk/support/products/imagerunner/imagerunner-advance-c5030i.aspx?type=drivers&driverdetailid=tcm:14-1506758&os=Linux%20(64-bit)&language=EN
        • AnotherBigAl
          • 34
          I had wondered about that before making the initial post. I am sorry if I got it wrong.
          Admin, can you move this entire post to the correct, Connectivity, forum please.
            • 22808
            no you must repost in the proper forum...
            i see the mention of Cinnamon 18.x are you sure that is what the linux version is? have you looked on the linux site for a better version
            • AnotherBigAl
              • 34
              I have reposted my original question in the Connectivity forum as you asked.
              Mint 18.3 Cinnamon is the current stable issue and has long term support. Additionally, all our machines are fully updated.
