1730 quality
  • copiman
    • Sep 2011
    • 861
    1730 quality
    I have a 1730 that when you use the adf to make a copy, the output is significantly lighter than when you use the glass to make copies. We did the adjustment as if we replaced the CIS but we did not actually replace the CIS. FYI, the main board has been replaced for other reasons (machine would not come up). Any ideas?
  • techandtrader
    • Jun 2016
    • 318
    Re: 1730 quality
    Developers that look good could need replaced. Esp. when they have junk toner in them or a generic. Solved the same kind of problem in a 1025 with a new developer. Customer buys toner from other places.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    • teckat
      • 16083
      Re: 1730 quality
      does that model have a doc Reader( copies don't feed to glass) inside the ADF ??
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        Re: 1730 quality
        Yes, it has a reader unit. ADF copies and Copies from the glass both use the CIS under the glass to reproduce the image. ADF copies feed across the slit glass while the CIS unit sits stationary.
        And the CIS unit moves the length of the copy for copies made on the glass.
        If the main board was replaced , they should have taken the time to print out the service data list for a copy of all the settings to re-enter after. However, if the copier would not come up......they probably did not have that option. Making adjustments in service mode will probably fix the variation in copy quality. I'm pretty certain there are separate adjustments for the CIS when using ADF feed and when using the glass.
        • teckat
          • 16083
          Re: 1730 quality
          Thanks for info,
          Trying to remember if there was a Tec pub on some iRC models with Slit Glass causing CQ issues ?
          • blazebusiness
            • 1250
            Re: 1730 quality
            Thanks for info,
            I can't remember.....that small black and white machine is older now. Just remember working on a bunch of them as recently as about 5 years ago. It was an ok machine for a monochrome unit and had color scanning. I don't remember them having too many CQ issues. Haven't seen one for a while now.
            • Scottb
              • Apr 2013
              • 303
              Re: 1730 quality
              The only CQ issue that I remember is the static eliminator sometimes causes issues, but it's been so long since I have see one I can't remember how it manifests itself
              • copiman
                • Sep 2011
                • 861
                Re: 1730 quality
                Thanks everyone. Been out of pocket. The main bd was replaced because it fried and there was no way to get info from it. I will look into other adjustments and see what I come up with. Will post if I find the fix.
