tray 4 jams at tray 2 registrstion area with jam code 0103. All other tray work great. Frsnk
Irc5045 jam code 0103 from tray 4 only
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: Irc5045 jam code 0103 from tray 4 only
Thanks for input Teckat. I am only one servicing machine in last year. Have not removed any connectors except on tray 4 pickup asm which I just changed due to the jamming Customer is over 20 miles away so I want to have a some more input before going back. FrankComment
0103 Is a Cassette 3 delay
Delay jam=Cassette 3 pre-registration sensorPS8
OK
things to check for a delay jam
Check the flag operation
The Cassette 3 Retry Sensor Flag is visible at the middle of the Pickup Roller.
The Cassette 3 Retry Sensor (PS8) is visible in the Cassette 3 Pickup Assembly.
: does it happen on all paper sizes
:did u check tray 3 and 4 operations in I/O - sensor , etc
: did u swap cassettes ?
: ? is this jam on copying & driver printing ?
: ? Is this a constant or intermittent issue ?Last edited by teckat; 07-13-2018, 12:09 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
0102/0103/0104/0A02/0A03/0A04 Jam Code due to deterioration of noise reduction material on the solenoid in the paper pick-up assembly.
To reduce noise, the pad [1] is attached to the solenoid (FK2-0408-000) used in the paper pick-up assembly.
As this pad deteriorates over time, the glue on the double-sided tape may become exposed. If this glue is adhered to the claw [a] of the solenoid, the return motion of the claw is delayed, resulting in a jam.
iR-ADV C5255 (for CE & Backend)|FAQ**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Only jams from tray 4
all sizes jam from tray 4
did not do a service mode i/o sensor .----not familiar with procedure
swapped trays and still jams from tray 4 so not a tray problem
lams from copying and from printing
jams every page
I will remove tray 3 pick up assembly and check solenoid + sensor , flag. If need be I can swap with old tray 4 pickup asm which I removed when replacing with new one. Evident;y i replaced wrong pickup asm but will resolve this and post results. Thank you Teckatfor all the extra info which is very helpful. I have seen that solenoid /felt issue on many machines including brother , HP etc.Comment
It seems the lower door may have been slightly warped due to customer intervention. Noticed when i pressed against it the paper always went through.
I improvise something with door to cause more pressure and has been working since. Will order new door for next visit..Thank you Techat for all yourhelp and info. FrankComment
