pick up issue
  • montana
    • Aug 2008
    • 393
    pick up issue
    hi.canon imagerunner 2202n.does not pickup from the cassette.i tried the bypass feed is good.i checked the pickup gear and the solenoid are fine.any help please.thanks
    Re: pick up issue
    is there a jam code?
    where is it jamming?
    what has been done to it?
    more info is needed
    • montana
      • Aug 2008
      • 393
      Re: pick up issue
      more info is needed
      no jam codes.it does not pickup a paper from the cassatte.but when i move the pickup gear manually it is start to pickup and feeds normaly and then i hear the solenoid tick with no pickup.thank you phil
        Re: pick up issue
        sounds like you have figured it out...
        next step solenoid repair - replace.
        can you watch in service mode the changes to the solenoid or to sensors?
