Canon ImagePass B2 Install
  • proditus
    • Dec 2017
    • 27
    Hello,
    I am trying to use a ImagePass B2 to a C5255. My ImageRunner C5255 has already installed the AR1 kits PCL and PS. Do I need to remove them in order to use the B2 ? My ImagePass B2, keeps restarting and I got it from a friend that had it in working condition. If so, how do I uninstall the AR1 Kits
    Thnx in advance !
    PCL PRINTER KIT-AR1
    PS PRINTER KIT-AR1
  • hutmah
    • Sep 2017
    • 18
    Re: Canon ImagePass B2 Install
    No you dont need to uninstall them but you need to set that an external controller is connected under options-img cnt in service mode. Should be set to 3
    • proditus
      • Dec 2017
      • 27
      Thank you ! It seems I am doing something wrong. Is there any sequence in connecting the cables and doing the reboots for the printer and the fiery ?
      It seems it doesnt recognize the fiery.
      • hutmah
        • Sep 2017
        • 18
        I believe you should set the value to 3 without the server connected. Turn the m/c off, connect the server and then boot it up starting with the server.
        Not sure if it has to be in that order but it works for me
