iR ADV C2020 Drum Installation Procedure
  • markdale25
    • Oct 2014
    • 3
    [Misc] iR ADV C2020 Drum Installation Procedure
    I have an iR ADV C2020 for which I am trying to replace the black drum. The procedure tells me to execute the following: Setting/Registration>Adjustment/Maintenance>Maintenance>ITB/Drum Cartridge Replacement Mode. The problem is my machine does not have the ITB/Drum Cartridge Replacement mode. The machine starts to initialize the drum unit after I install it but fails after it starts the gradation adjustment. Has there been a system update that added the ITB/Drum Cartridge Replacement Mode? I don't remember having to do this in the past and I'm not seeing it explained anywhere here in the forum.
  • tech28
    • Jun 2013
    • 434
    Re: iR ADV C2020 Drum Installation Procedure
    YouTube it, there are a few on how to. Rebuilding instructions also. Have found a way to reset drum counters on those machines also and lock it in.
    Good luck.
    • JPiek
      • Oct 2014
      • 435
      What do you mean 'it fails after it starts the gradation adjustment' ? t give's an error, or Gradation adjustment fails to finish ?
      For the last one, try : COPIER > FUNCTION >CLEAR > REG-CLR (it's in Level 2), then retry Full Gradation
      Johan
      • MunsterTech
        • Sep 2014
        • 377
        you need to turn the itb/drum replacement on when using maintenance, if i remember off hand , service mode, display switch or function switch, something along the lines of itb, use the green info button and you will find it, no need to reboot, go back into maintenance under smart head /user mode and then it will do its thing
        • nicknt82
          • Nov 2011
          • 155
          switch it On :service mode copier / option / display-sw / itb-dsp set to a 1.
          If it can't solve. Replace back the chip on old drum to new drum
