canon ir adv 6255
  • smiley
    • Aug 2008
    • 615
    canon ir adv 6255
    good day guys. one of my ir adv 6255 jams intermittent in transfer belt before entering the fixing. it looks like the paper fold on the edge that cause the paper jam.any one got experience this pleased help me thanks.
    there is no glory without sacrifice
    Re: canon ir adv 6255
    ok..
    1) jam code
    2) life on ALL consumables
    3) with ANY TONER BASED LIFE FORM... Z Fold @ fuser... CHECK FUSER! how many pages on it?
    4) have you pulled consumables (drums/fuser/belt) manually/visually inspected them? in good shape.. no toner buildup at fuser entrance guide? fuser gears/rollers spinning smooth?
    LASER PRODUCTS 101
    • smiley
      • Aug 2008
      • 615
      thanks for the reply phil B. the machine already have 600k copies on it . the machine are all clean the fuser feel soft when i turn the knob. i will check the jam code and post it later. thanks.
      • nicknt82
        • Nov 2011
        • 155
        you should show jam code , upload some pictures. And jam happend on single side or double sides?
        • smiley
          • Aug 2008
          • 615
          the jam codes are. 212 213. and always happend in 2 sided copy.
          • roho
            • Mar 2009
            • 844
            Change both coronas and ETB. Try that and clean the fuser inlet guide.
            • tech28
              • Jun 2013
              • 434
              Just had a Canon IRC 2550 last week, customer complaining that it would jam in duplexing consistently, we would go there and pull machine out of the spot it was in and it would not miss a beat. Push machine back in the spot it was in and boom, jam. After doing some checking, floor was uneven. Moved it to different location, now, no jams. Just don't know what causes problems sometimes.
              • smiley
                • Aug 2008
                • 615
                hi roho what coronas i should change the primary and pre trans?
                • nicknt82
                  • Nov 2011
                  • 155
                  Print one by one paper on double side and take picture at paper jam. Maybe still have some piece of paper stuck on paper path.
                  • roho
                    • Mar 2009
                    • 844
                    Yes, both. Sometimes the pretransfer can be soiled and not charging as well as it should and can cause the paper to flutter around. If you are still having issues check the fuser as well, I believe you thought it felt soft. All these parts are consumables, and will need to be changed.
                    • sal
                      • Dec 2011
                      • 19
                      I was unable to find 212 or 213 error code can you verify the error code
                      • sal
                        • Dec 2011
                        • 19
                        My bad they are jam codes sorry.
                        • smiley
                          • Aug 2008
                          • 615
                          yup they are jam codes. sometime paper stops at delivery roller. i try to clean the sensor and i was surprise it continue to print without a jam.
