Canon Adv C5045 - blank screen
  • kuby
    • Oct 2007
    • 1414
    Tech has Canon ImageRunner Advance C5045 that when you turnon the power switch the fans for the main boards come on a run but nothing elsehappens. No motors come on, no fans, no display, Nothing.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Canon Adv C5045 - blank screen
    Have you tried booting it into service mode?
    • teckat
      • 16083
      Main Controller 1😱
      • kuby
        • Oct 2007
        • 1414
        Have replaced main controller 1, still no luck. Just fans on MC 1 and MC 2 running.
        guitar9199:
        Can not boot into service mode, copier will not boot?
        Tired Boot System Diagnosis, Turning on the Main Power Supply Switch while pressing the Control Panel Power Supply Switch, but when the machine does not try to boot this does not work either.
        And tired the other diagnosis tool, it does not work either.
        • kuby
          • Oct 2007
          • 1414
          Replaced power supply still no luck. And power supply fan works.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Try to boot with all doors open.
            Maybe is Main PCB2
            Before replacing the Main Controller PCB 2, upload SramImg.bin. By downloading
            SramImg.bin after replacement, the new Main Controller PCB 2 inherits the data
            including Service mode stored in the old PCB
            • kuby
              • Oct 2007
              • 1414
              Tried that, same results. Power LED on, fans run, no boot.
              • zoraldinho
                • Mar 2008
                • 5018
                When you replace Main controller 1 did you transfer the parts from old PCB to new PCB? Especially Flash PCB specifically responsible for the boot!
                • kuby
                  • Oct 2007
                  • 1414
                  Yes, we transferred the parts.
                  • apoxi
                    • Nov 2015
                    • 45
                    I had this on C3330 series. The HDD was a problem. When i change HDD, power on machine 2+8 keys and reload firmware.
                    • kuby
                      • Oct 2007
                      • 1414
                      Replacing the hard drive does not work, can not get to download. Nothing on the screen.
                      • Midhun maliyil
                        reliable tech
                        • 4
                        h,i is the problem solved?
                        • kuby
                          • Oct 2007
                          • 1414
                          Nope...
                          • Service@PRT
                            • Oct 2016
                            • 181
                            Put back the old parts...
                            If i remember correctly, it happened to one of our client.. what i do is reseat all the chips on mc 1 and mc 2. And after that reseat the connection on the rightside of the mc2 the big dirty white connectors.. near the fax socket. Then it works....
                            There is 2 on mc1 and 3 on mc2...
                            Sent from my HUAWEI VNS-L21 using Tapatalk
                            Every day of life is a learning process...
                            Just make sure you are open in all aspects of comments.
                            • techandtrader
                              • Jun 2016
                              • 335
                              WTH ?
                              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
