Adv 6555 Image Quality Problem
  • tamboknon
    • Sep 2015
    • 62
    Dear All,
    I experiencing this problem with a new machine Adv6555 only installed a month ago and have a meter reading of 10k only both printing and copy problem. I already isolated developing assy, cleaned the drum unit and checked the ETB if its going to the drum and primary charging assy. When I off the potential no changes happen and also doing some adjust in primary still the same. Hoping for your quick response. Thanks in advance.
    I cannot upload the sample copy sorry I've having some issue uploading. Its like a blurred copy.
  • teckat
    • 16083
    Re: Adv 6555 Image Quality Problem
    Originally posted by tamboknon
    Dear All,
    U didn't explain what the image issue is ?
    U mention blurred at end of post, is that the CQ issue ?
    • Etech50
      • Oct 2017
      • 28
      Most likely it is the dev middle stir rod, take the upper cover off of the dev and see if it is not attached. (FL3-2163-010) It has been an issue on all adv6000 series, the part has recently been modified to reduce breakage. I usually replace the just the rod and not the whole dev. It can be changed easily but can be messy, just pay attention to the orientation of the 3 rods as they need to be in correctly.
      • tamboknon
        • Sep 2015
        • 62
        Sorry for the late reply. I already solved it by replacing transfer high voltage pcb underneath the ETB. Thank you so much for quick response.
        • techandtrader
          • Jun 2016
          • 335
          The developer contact can cause a back ground. Junky print too.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
