Canon IR adv 7065
  • Nestopee
    • Feb 2018
    • 28
    Canon IR adv 7065
    Good day I'm looking for Canon IR adv 7065 service manual and how to reset the waste toner value and fixing roller values.
    Regards Nestopee.
  • teckat
    • 16083
    Re: Canon IR adv 7065
    Regards Nestopee.
    <Related Service Mode>:
    COPIER>FUNCTION>CLEAR>W-TN-CLR: Clear the waste toner counter.
    COPIER>FUNCTION> MISC-P>WTN-OFST: Offset the waste toner full level sensor.
    Waste Toner Container
    1) Clear the Waste Toner Counter. (COPIER>FUNCTION>CLEAR>WTN-CLR)
    2) Install a new Waste Toner Container.
    3) Execute the offset adjustment of Waste Toner Full Sensor. (COPIER
    > FUNCTION > MISC-P > WTN-OFST
    Waste Toner Sensor
    1) Install the Waste Toner Container.
    2) Execute the offset adjustment of Waste Toner Full Sensor. (COPIER> FUNCTION > MISC-P > WTN-OFST)
    Be sure to clear the counter value when the waste toner container is replaced.
    Fixing belt unit
    Clear the counter.
    COPIER > COUNTER > DRBL-1 > FX-BLT-U
    NOTE:
    When the foregoing counter clear is executed, the following item is cleared.
    COPIER > DISPLAY > FIXING > FX-U-TM1-8
    COPIER > DISPLAY > FIXING > FX-U-STR
    Pressure belt unit
    Clear the counter.
    COPIER > COUNTER > DRBL-1 > FX-BLT-L
    NOTE:
    COPIER > DISPLAY > FIXING > FX-U-STR 2-8
    Fixing assembly
    1) Clear the counter.
    COPIER > COUNTER > FIXING > FX-CNT
    COPIER > COUNTER > DRBL-1 > FX-BLT-U/FX-BLT-L
    NOTE:
    COPIER > DISPLAY > FIXING > FX-U-TM1-8 / FX-L-TM1-8 / FX-U-STR / FX-MTR2-8
    • Nestopee
      • Feb 2018
      • 28
      Good day Teckat, thank you so much.
      • teckat
        • 16083
        COLOR HAND.jpgwelcome !!
