Desprate help with Imagepress c6000 delay jam
  • Kwaku01
    • Aug 2018
    • 121
    Getting paper jam at UNIT B-D, just before going through the primary fixer. Delay jam...code 0112, PS200. Image attached....I've clean and swop sensors but stil getting jam. Any suggestions, please help!
  • teckat
    • 16083
    Re: Desprate help with Imagepress c6000 delay jam
    0112 is a Delay jam to PS200 (Pre Fixing Feed Sensor). The paper is stopping at the Left Transport Belt assembly.
    Rotated the left transport belts by hand and they did not feel the same as the right side transport belts.
    The belts would turn easy sometimes and then get hard to turn.
    Took the drive motor (M181) off and the drive gear was loose.
    The drive gear set screws loosened up causing the drive gear to shift.
    This caused the assembly to bind.
    Put the drive gear back on and tightened the set screws.
    • Kwaku01
      • Aug 2018
      • 121
      Thanks alot for your help once again! Please which is "The drive gear set screws"?
      • teckat
        • 16083
        check on back of the motor
        • Kwaku01
          • Aug 2018
          • 121
          You legend! It worked. Thanks heaps!!!
          • teckat
            • 16083
            Macgyver.jpgwelcome
            • Kwaku01
              • Aug 2018
              • 121
              [ATTACH=CONFIG]40446[/ATTACH]welcome
              I bought canon imagepress c6000 secondhand, after installation, I keep getting error after errors. The new errow is, E110-0201. I've no clue how to go about this one...any help will be greatful!
              • teckat
                • 16083
                E110-0201 = Magenta laser
                For trouble shooting purposes swapp J1112 (yellow laser scanner power cable) and J1122 (magenta laser scanner power cable) on DC-CON 1-3
                see if error code moves to Yellow
                (E110-0101)----------if error switches---most likely DC-Controller 1-3 (FM2-7687-000) not supplying power to connector
                ============================or
                E110-0201 points to the Magenta laser scanner motor that does not reach a certain speed within a specified period.
                In this case, checking the connection of the magenta video cable, swapping the magenta laser unit, performing DCON clear and clearing the error code in service mode did not change the symptom.
                In this case, replacing the DC controller PCB 1-3 (UN240) resolved error code in the field. DC controller PCB 1-3 Assembly FM2-7687-000
                E061-0291
