IRC1030 cycles when connected to network
  • RHodg57
    • Dec 2013
    • 191
    This copier keeps recycling/rebooting when the network cable is connected to it. When I connect it to my laptop
    it works just fine. I told the customer that it might be a problem with their modem for their internet. They are going
    to have their internet service check it out. I have never seen anything like it. I moved the copier cable to a different
    slot on the modem and shut the modem off and on. Same problem. Anyone ever heard of a machine doing this?
  • teckat
    • 16083
    Re: IRC1030 cycles when connected to network
    Try turning off Multicast Discovery
    System Management Set. > Network Settings>TCP/IP Settings>WSD Print Settings>Use Multicast Discovery_ OFF/ON*---default setting is ON*
    Additional Functions > System Manager Settings > TCP/IP Settings > WSD Print Settings > Use Multicast Discovery "OFF"
    Power off the imageRUNNER for the changes to update on the machine. Power unit on.
    If that fails----try
    System Settings>Network Settings>TCP/IP Settings>WSD Printing Settings> Use WSD Browsing default is on, set it to off .
    A 3rd party PCL print driver can also cause the problem.
    One solution was to install the Canon UFRII print driver.
    • RHodg57
      • Dec 2013
      • 191
      Checked all those settings and they were off. Loaded UFRII drivers on their computers. Tried a different cable.
      No Joy......I got back there before the internet person showed up. Is it possibly a modem problem?
      • 20 year tech
        • May 2014
        • 577
        Could be the customers network is using POE or power over ethernet, put a non POE hub between the network and the machine and see if it goes away.
        • aAandy
          • Apr 2012
          • 370
          i've seen exactly this issue many a time before with multiple different makes and models - you won't believe the solution, but it works
          remove the machine from the network entirely, change the IP address in the machine (use CMD to ping your new IP address to ensure it's not already in use), then install printer using that new IP address
          depending on your clients' setup, you may have to remove & reinstall on every computer they have - make sure you download the latest driver from the manufacturer,,, never use the generic Windows drivers, they suck
          also do NOT use WSD type "port" - make sure to use TCP/IP port (in other words the actual IP addy of the machine) - WSD causes so many problems it's not funny
          • RHodg57
            • Dec 2013
            • 191
            Okay. Thanks!!
            That seems to have solved the problem. No cycling and it printed just fine. Just out of curiosity, why did that IP address
            that they have had for a long time now suddenly start causing issues?
            I did ping the old IP with the copier disconnected from the network to make sure there wasn't a conflict.
            • JPiek
              • Oct 2014
              • 435
              It is if you get payed by the hour
              But seriously, it does seem to mess up a lot. Install printer - test - it prints. Come back next day - it doesn't. Cannot find printer... Installed by IP, no more issues...
              Johan
              • Kimi
                • Feb 2018
                • 105
                Ive seen this fault before on KM's, rogue print job causing the device to reboot.
                • aAandy
                  • Apr 2012
                  • 370
                  Okay. Thanks!!
                  to this day i have not been able to ascertain exactly why, and i've been repairing computers since '83 - no IT 'expert' has been able to tell me why either
                  • aAandy
                    • Apr 2012
                    • 370
                    lol, i do get paid by the hour - field service engineer contractor and i work on many different types of machines other than copiers & printers
                    • techandtrader
                      • Jun 2016
                      • 335
                      I have seen this problem on a $500 HP about 7 years ago. Unplug the cat 5 and clear the print job.
                      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                      • petermays
                        • Mar 2017
                        • 91
                        yes.its a IP CONFLICT.
