Adv4225 Offline
  • repeatcopiers
    • Sep 2008
    • 591
    Adv4225 Offline
    Installed an Adv4225 yesterday, it was working fine. After about 5 hours customer called to say it won't print anymore and on the computer it says the copier is offline? Copy functions seem fine. Any ideas before we head out there?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Adv4225 Offline
    If there are no major problems, the copier is set to dhcp and has acquired a different ip than the user has on the driver.
    • repeatcopiers
      • Sep 2008
      • 591
      Re: Adv4225 Offline
      We have verified that the DHCP is OFF and the IP address is still correct.
      • zoraldinho
        • Mar 2008
        • 5018
        Re: Adv4225 Offline
        Try with new utp cable.
        Set energy settings on copier.
        Can you ping the printer?
        Maybe IP conflict?
        You can always connect printer directly to laptop to isolate network issue.
        • guitar9199
          • Sep 2016
          • 1100
          Re: Adv4225 Offline
          I've seen this one hundreds of times. Go to your "Printer Properties", click on the "Ports" tab and then "Configure Port".
          Uncheck the "SNMP Status" box, and your issue will go away. For some reason if that's checked, and the computer and copier lose communication, the only way to reconnect is to reboot both devices. Unchecking that box, the machine will reconnect the next time a print job is sent.
          Like I said... I've seen it hundreds of times. I've seen it across different brands too!
          • repeatcopiers
            • Sep 2008
            • 591
            Re: Adv4225 Offline
            Walked customer through this over the phone. Then had them reboot computer and copier, still won't print, says copier is in Error State? Tech is going on over to check it out, any other ideas?
            • repeatcopiers
              • Sep 2008
              • 591
              Re: Adv4225 Offline
              They are printing now, plugged it into another port on their router. Emergency is solved, however there is something else I'm not sure about. At the bottom left hand corner of the display screen, there is a little lock symbol that I haven't seen before. Does someone know what that is?
                Re: Adv4225 Offline
                Adv 4225 Offline fixed now a LOCK showing on screen - Google Search
                Google is a good friend... techs can access via smartphones
