canon imagepress c6000 transfer belt issues
  • Kwaku01
    • Aug 2018
    • 121
    Hi All,
    Please does anyone know if canon imagepress c6000 transfer belt with imprint dots, causing white dots on solid prints, can be fixed or It has to be replaced?
    If it can be fixed, how? if not, where to get a secondhand or new one. Tnx
    Screen Shot 2018-08-22 at 2.14.08 pm.jpgScreen Shot 2018-08-22 at 2.13.48 pm.jpg
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: canon imagepress c6000 transfer belt issues
    Old belt can not be fixed.
    google it: FM3-1644 Intermediate transfer belt (ITB)* lifetime 1000 000
    With belt replace also:
    ITB inner cleaning scraper* FM2-2145
    ITB end scraper FL2-2025
    ITB cleaning brush roller* FC5-9156
    ITB cleaning web* FC5-9197
    ITB cleaning blade* FC6-4910
    Primary transfer roller* FC6-1545
    Secondary transfer roller* FC5-9252
    It may be tired developer.Check condition of developer powder.
    Check quality of paper.
    Make a force stop to isolate fixing.
    Post please a PG-10 test.
    I have feeling.. this machine is too big for you.
    • Kwaku01
      • Aug 2018
      • 121
      You are soo right about the machine being too big for me...I bought canon imagepress c6000 secondhand, After installation, I keep getting error after errors. The new errow is, E110-0201. I've no clue how to go about this one...any help will be greatful!
      • zoraldinho
        • Mar 2008
        • 5015
        E110-0201
        When the Magenta laser scanner motor does not
        reach a certain speed within a specified
        period
        Remedy:
        1. Check if the connector at laser scanner unit is disconnected/
        not securely inserted -> disconnect and then connect the
        connector
        - connector at the laser scanner unit
        - connector at the DC controller PCB 1-3 (UN240)
        2. Check if the harness between the laser scanner unit and DC
        controller PCB 1-3 is disconnected/caught by a unit
        3. Replace the laser scanner unit
        4. Replace the DC controller PCB 1-3
        • Kwaku01
          • Aug 2018
          • 121
          E110-0201
          period
          Remedy:
          connector
          Thanks for your immediate response. Please where is the laser scanner unit located?
          • zoraldinho
            • Mar 2008
            • 5015
            Don't do that.Must remove hundred screws,disconnect 50 connectors and slide the toner unit.Only for trained tech.
            • Kwaku01
              • Aug 2018
              • 121
              My goodness! What do I do then? I've had a tech guy from canon come in twice and was not able to correct fix the errors that I've managed to fix myself with the help of you guys. We live in a country town and there are not any tech guys here. Is there some where I can disconnect and connect again. It's worth a try...it was working fine this afternoon.
                first thing to do is get the Service Manual.... if you don't have one DO NOT TOUCH the unit.. you will make things worse.
                  • Kwaku01
                    • Aug 2018
                    • 121
                    I have the service manual...but first I will:
                    connector
                      ok you say you have service manual... -= IF =- you want to try pull/connect wire harnesses back let me give you a few bits of advise...
                      1) TAKE PHOTOS of all side of that board BEFORE pulling even one harness
                      2) take a Sharpie and mark ALL open connectors on the board
                      3) be VERY CAREFUL when pulling/reinstalling the FCC's (flat cable connections) if you bugger one of the lans on the cable you are SCREWED. Some have black slides that lock the cable in place... MAKE SURE you insert the cable STRAIGHT into the connector.
                      4) get an anti-static wrist band and hook it to the METAL FRAME of the unit and to your wrist... I also touch the frame any time I shift my body ( static ) or moving to push harness out of the way. ( boards are HIGH $$$ and can be damaged due to static electricity VERY EASILY!!
                      good luck..take it slow...measure twice, cut once.
