canon ir 7105 duplex paper crumbling issue
  • geltrons
    • Apr 2007
    • 37
    good day all
    i am facing a strange problem in canon ir 7105 .
    the paper feed to duplex unit is crumbled and stuck
    pls refer the attached image
    i have done everything possible by me .
    renewed the two sensors ps11 and ps 12, cleaned the rollers , checked the solanoid etc
    kindly some body help
    regards
    thomson
  • floody
    • Mar 2017
    • 37
    Re: canon ir 7105 duplex paper crumbling issue
    looks like its jamming at the rollers? is there an out-put mode to test the duplex motor?
    • Brian8506
      • 1664
      That top plastic guide does warp. I have had to replace that for jamming in that area. There is a heavy spring on each end that may cause it to warp overtime. Those rollers also get slick And need to be replaced periodically
