Canon C2020H Error E602-001
  • pdpyen
    • Dec 2024
    [Error Code] Canon C2020H Error E602-001
    hello all,
    i have a canon copier C2020H.
    I am getting this code when i turn the machine on.
    Im gonna be honest and tell each step i have taken before i got this error.
    Disassembled the back part of the machine to check if HDD exists, as i was unable to print pdf directly from the machine via USB drive
    HDD is a 160gb seagate SATA.
    i then connected it(hdd) to pc.
    dint show up, thought it was baked and went to disk management, and there saw some 20 odd sized partitions.
    then i deleted all of them and then reconnected the drive to the copier.
    Ended up with E602-001.
    Since this is caused by me, i believe that the machine is fine except for the hdd(firmware part)
    now, i have worked on ricoh before but i have limited knowledge of Canon.
    I have a service manual for this model.
    Counter : around 400000 in all(color + black)
    I have so far understood that i need SST and C2020H firmware.
    But unable to source it till now.
    Itd be of great help if anobody could assist me please.
    Thanks.
