Part # c7055/c9065/c7060 Manual feed guide
  • ReproKev
    • 267
    I can find the part in the manuals but no number associated with it.
    It's the center paper guide directly under the manual feed roller. It has a thin metal plate on it that gets damaged over time causing jams.
    I need either the whole guide with the metal plate or the metal plate by itself.
  • teckat
    • 16092
    Re: Part # c7055/c9065/c7060 Manual feed guide
    [ATTACH=CONFIG]40487[/ATTACH]
    think u need---it locks into the MULTI TRAY, UPPER
    FIGURE 315 MULTI TRAY ASSEMBLY
    #11----
    FL3-3172-000 1 PLATE, MULTI PRESSURE
    • ReproKev
      • 267
      Thanks, but it's definitely the part I circled in the pic I posted. It's the center one of the 3 paper guides that sit below the manual feed roller and are accessed with the mf door open. It has a thin metal plate on it and a sensor arm mounted on it.
      I just pulled one out of a parts machine and found part # FC9-4033 molded on the back but that number doesn't come up with any of my vendors or a web search (I'm not a Canon authorized dealer). Can anyone confirm that part # or maybe cross reference it to get the correct one?
      • teckat
        • 16092
        [ATTACH=CONFIG]40501[/ATTACH][ATTACH=CONFIG]40502[/ATTACH][ATTACH=CONFIG]40503[/ATTACH]
        the latest parts catalog-------------- still has no number for that part--------------
        imageRUNNER ADVANCE C9075 PRO/C9065 PRO/C7065/C7055 Parts Catalog (Rev 5, June 2018)
        Date 6/15/2018
        • nicknt82
          • Nov 2011
          • 126
          I think. Here are your need
          • teckat
            • 16092
            [ATTACH=CONFIG]40506[/ATTACH][ATTACH=CONFIG]40507[/ATTACH]
            FL2-8891-000 Paper Feed Middle
            what version parts catalog did u find this in ???
            found online in Rev.1 catalog -----------------great find
            • nicknt82
              • Nov 2011
              • 126
              It's Rv 2.0. Jul 27 2010
              • ReproKev
                • 267
                Thanks!! That's exactly what I needed!
                • teckat
                  • 16092
                  now to find it
                  seen a listing on DSNproducts.com for 5.23
                  no picture---description fits
                  but add has Booklet-Fin B1 in listing ????
                  • ReproKev
                    • 267
                    now to find it
                    That's where I ordered it from. I'll post back when I get it whether it's the correct part or not.
                    • ReproKev
                      • 267
                      Update - I was told the part is discontinued. Odd, because it's the same part used on the c7260's and they're not that old.
                      • teckat
                        • 16092
                        I would call Canon
                        +1-800-652-2666
