Frequent paper jams on a Irad 8105, from paper deck. I have replaced the pick up feed assembly and M1. No change. The paper will get to the registration guide of the machine and will fall out as soon as the door is opened. Only happens from the deck. The entire pick up assembly has been replaced. Has anyone else had this issue?
0218 jam code paper deck unit c1
Re: 0218 jam code paper deck unit c1
Frequent paper jams on a Irad 8105, from paper deck. I have replaced the pick up feed assembly and M1. No change. The paper will get to the registration guide of the machine and will fall out as soon as the door is opened. Only happens from the deck. The entire pick up assembly has been replaced. Has anyone else had this issue? -
I did on a 6XXX series. It was the right door. Either warped or worn (the guides). I think canon had a update on a piece in the middle. It was on a used machine new install. The deck may have been new. We thought at first it was the carpet and was not lined up. It would feed out and intermittent jam. Do not remember jam code. Try pushing on the door and see if it feeds. Had another machine I took the door off and have never gone back for feeding problems since. Top big door that closes over developer.Comment
