Swapped out drums. DC Con clear. Replaced drum contact PCB and connecting pcb assy. Nothing has worked so for. Any ideas welcomed.
IRA C5560i Insert the drum cartridge (black)
Re: IRA C5560i Insert the drum cartridge (black)
Check the Black DRUM GROUNDING PLATE, --------item #2
sits under the drum (there are four of them-one for each color )
this is a pic of the c5035 unit
Try Re positioning the springs on the Drum Contact PCB
Example shown on Yellow
The following image shows undamaged spring contacts. The operator side of the drum unit makes contact with them.
Last edited by teckat; 09-06-2018, 05:52 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
