Canon IPC600/700/800 Error code E012-0100
  • nicknt82
    • Nov 2011
    • 155
    [Error Code] Canon IPC600/700/800 Error code E012-0100
    Canon IPC600/700/800 start up with E012-0100 after warm up time. All Drum /ITB motors no turn but can turn manual easily no stuck. I take out all Drum unit, ITB for check with no problem.
    Do Everybody has experiences about this problem? Thank you!
    Re: Canon IPC600/700/800 Error code E012-0100
    run motor test in service mode..start with ITB test
    • nicknt82
      • Nov 2011
      • 155
      With this error code, I can't run Test any motor.I tried before. Any ideal else?
        did you try the ITB test with drums out and vice versa? I know the older models you could
        • nicknt82
          • Nov 2011
          • 155
          [QUOTE=Phil B.;699470]did you try the ITB test with drums out and vice versa? I know the older models you could[/QUOTE
          Can't sir. Because Drum and develop has connector. When we take out cartridge and turn on will be error E020 or E024. I tried to do it in another case.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            [QUOTE=nicknt82;699480]
            It's not necessary to yell though Phill is old.
            I'm not familiar with this model but E012 on color models can be a bad drum drive pcb or only dirty encoder sensor.Use compressed air.
            • nicknt82
              • Nov 2011
              • 155
              [QUOTE=zoraldinho;699507]
              I'm on mạchine now. I clean encoder of ITB , Drum Y. Event change drum drive between Y and C together, drum drive same to gether and have encoder, motor on it.
              But error code and sub code still no change E012-0100
                ehhhhhhhhhh sonny I made be old but I ain't deef yet!
                  yeah thanks for the reminder bud!
                  • guitar9199
                    • Sep 2016
                    • 1100
                    I don't think that was intentional.... When I access CTN on my smartphone, sometimes the font comes back as "Yuge", and it looks similar to this.
                    ....or he was being a smart-alec.... Either way works for me...LOL!
                    • nicknt82
                      • Nov 2011
                      • 155
                      Thanks all of you !.The reason is Drum Y,M,C motor fault. I don't know how because motor's usually very difficult damage. Wait for replace new motor ass'
                      • zoraldinho
                        • Mar 2008
                        • 5007
                        I doubt about diagnosis. Probably will be a power supply or a main controller.
                        Motor ass..
                        Click on pic.
                        • nicknt82
                          • Nov 2011
                          • 155
                          Motor ass..
                          Click on pic.
                          [ATTACH=CONFIG]40601[/ATTACH]
                          I mean motor assembly ^^
