IRA6265i blank screen
  • jiongpao
    • May 2009
    • 413
    Hi.
    Im new with this model. few days ago it run smoothly till yesterday when we turn on the machine it blank screen with power light on. I can't press anything. No warming up sound. last seen meter usage 930k since last week.
    I changed whole power cord terminal assy and the problem still the same
    Before i try to change other parts i want to know from ya guys any other possibility part failure that cause it blank screen? Thank you and i appreciate it.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IRA6265i blank screen
    Main board probably
    • roho
      • Mar 2009
      • 844
      Yes, possible main controller, however I had this as well and turned out to be the power supply. We had a machine in the back so I took the entire assembly and it worked, I believe there were 2 different power supplies on the assembly. The only way to really know for sure which way to go is to check voltages with the manual. Yes, a real pain, but otherwise you will be tossing expensive darts.
      • jiongpao
        • May 2009
        • 413
        Thanks guy end up main pcb failure
        • zoraldinho
          • Mar 2008
          • 5007
          Not good..
