Canon Ir adv 8205
  • Saji
    • May 2010
    • 97
    Canon Ir adv 8205
    Canon ir advance 8205, giving e 61-000, I checked,and replaced pretransfer corona,and sensor,it works fine in another machine.what could be the other reasons for the error. Please help.
  • roho
    • Mar 2009
    • 844
    Re: Canon Ir adv 8205
    Check the primary corona, more likely the cause of that error then the pre transfer.
    • Saji
      • May 2010
      • 97
      I replaced primary corona and the sensor as well.but problem remains.thanks
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Can you print a test page with potencial control off?
        Inspect quality of drum surface.
        • ReproKev
          • 273
          High humidity location? I had a similar E061 problem with a customer running a machine out of their home garage.Turn off potential control until the environment improves. Quality will probably suffer but that's not your problem if the customer doesn't control the copiers environment.
          • Saji
            • May 2010
            • 97
            I off the potential control,but still the error coming. Any other things I have to check? Kindly help.
            • Saji
              • May 2010
              • 97
              • guitar9199
                • Sep 2016
                • 1100
                • nicknt82
                  • Nov 2011
                  • 155
                  Also check Drum lock Screw or groud plate inside Drum after check Transfer unit
