Ir 3300 is showing white (erasing) streaks
  • Andyboachie
    • 185
    Hello,
    I'm about to work on an IR3300, with white erasing streaks that has just started at the left vertical side of the copy. There is enough toner. Apart from the drum, does anybody has another suggestions?
  • Brian8506
    • 1667
    Re: Ir 3300 is showing white (erasing) streaks
    Drum
    Sent from my iPad using Tapatalk
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5019
      • Andyboachie
        • 185
        Originally posted by zoraldinho
        Thanks for the response. But as I said, a suggestion of the drum as the problem should be ruled out. I have replaced the whole drum unit, but the erasure still continues.
        I have changed the toner unit also.
        What happens is: the left side of the copy erases. As more copies are tried, on A4R layout, one or two of the copies might appear rotated across the height of the sheet, as if it was copied on A4 layout.
        • Brian8506
          • 1667
          • zoraldinho
            • Mar 2008
            • 5019
            Post a sample!!
              my bet is toner clumps in the Dev unit... but without EXAMPLES no one can be sure .
              • Andyboachie
                • 185
                Hi,
                Thanks for the suggestions. It worked after i changed the laser unit.
                So pleasant to have you around guys!
