Ir3530 power problem
  • zajednobor
    • Sep 2013
    • 3
    I have canon ir3530 problem is when i switch on the machine there is no display on screen.machine makes starting sounds and shows power indicator
    Can you help me?
  • guitar9199
    • Sep 2016
    • 1100
    Re: Ir3530 power problem
    After the machine stops making startup sounds, can you press the start button and make a copy?
    • zajednobor
      • Sep 2013
      • 3
      No I can't.
      No signal light on green button
      • guitar9199
        • Sep 2016
        • 1100
        Originally posted by zajednobor
        No I can't.
        Try starting the machine in self diagnostic mode (power on with 2&4 held down until "Box Checker" is displayed - about 20 seconds). If you still have nothing, it's likely your low voltage power supply.
        • zajednobor
          • Sep 2013
          • 3
          still have nothing
          Thanks for your answer
