Adv6255 slow scanning
  • repeatcopiers
    • Sep 2008
    • 591
    Customers Adv6255 is scanning at a very slow rate. It will scan in the document then after about 3 or 4 minutes it will scan in the 2nd document, etc. Any ideas?
  • teckat
    • 16083
    Re: Adv6255 slow scanning
    Are u scanning yo email
    • repeatcopiers
      • Sep 2008
      • 591
      Yes they are scanning to email. They also have an ir6055 in the office that scans to email just fine.
      • repeatcopiers
        • Sep 2008
        • 591
        They are scanning to email, is there a setting that needs to be changed?
        • roho
          • Mar 2009
          • 844
          We set everything to PDF compact, see if those settings match.
          • teckat
            • 16083
            Scan and Send
            • repeatcopiers
              • Sep 2008
              • 591
              Yes, even when copying using feeder, it will intermittently stop and says scanning, eventually it will scan them all in but it takes a very long time.
              • teckat
                • 16083
                open that link , may show some adjustments
                • guitar9199
                  • Sep 2016
                  • 1100
                  Almost sounding like you might need to update your firmware... Especially RCON.
                  Try doing an RCON Clear in service mode first.... especially since it's doing it with copies as well as scans. ....Make sure you have your P-Print handy FIRST!!! It saves you a TON of headaches re-configuring everything after a clear!
