On an IRC2380 I have a dominant of yellow,
  • philippe69
    • Aug 2015
    • 2
    [Misc] On an IRC2380 I have a dominant of yellow,
    Hello everyoneI am new on the forum and after some research I did not find a subject corresponding to my problem.On an IRC2380 I have a dominant of yellow, that is to say that the prints as the copies pull too much on the yellow.I made the color settings accessible in the users menu but it does not change anything.I guess it must be tuned in Tech mode. But I do not know enough Canon to advance on this field.I add that the 4 drums are new.Can you help meThanks in advance.
    Hello everyoneI am new on the forum and after some research I did not find a subject corresponding to my problem.On an IRC2380 I have a dominant of yellow, that is to say that the prints as the copies pull too much on the yellow.I made the color settings accessible in the users menu but it does not change anything.I guess it must be tuned in Tech mode. But I do not know enough cannon to advance on this field.I add that the 4 drums are new.Can you help meThanks in advance.
  • ReproKev
    • 273
    Re: On an IRC2380 I have a dominant of yellow,
    Set all the color density settings in the user mode to "0" and do a full gradation.
    • teckat
      • 16083
      See manual
      https://I'm reading "Canon iRC2380_2.../doc/311632401
      • philippe69
        • Aug 2015
        • 2
        Thank's for your answer,
        I do that in the user settings but no change...
        • teckat
          • 16083
          Not a user setting issue,
          First read manual about calibration.
          If u have an external server, remove it's calibration
          Next, do a Full Auto Calibration from control panel
          The calibrate the fiery _ u will need a color calibration strip for that.
          After all that, u then work on your color issue.
