c5245 Insert toner. Change toner. Wait Message
  • techandtrader
    • Jun 2016
    • 332
    Change the Hopper and the drive gear unit. Reseated Drum driver board. Checked IO and those looked good. No change after replacing parts. It is also showing a preparing toner message. Rand several Dcon clears and toner stirs. These did not help. Always gives the message to replace the mag toner. Updated software about a week ago with latest SST
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • teckat
    • 16083
    Re: c5245 Insert toner. Change toner. Wait Message
    Replace Toner Message
    This can happen in any color but in this example the message appeared for black.
    n a few cases*
    It was found that toner container inner cover sensor PS16 was not changing states in I/O mode when the door was opened manually. P024 bit 11(bit 10 for cyan, bit 9 for magenta, bit 8 for yellow).
    Replacing the sensor resolved the problem.
    The part number for the senor is WG8-5783-000.
    There pictures below show the location of the drum driver board and toner container inner cover sensors.
    • techandtrader
      • Jun 2016
      • 332
      This turned out to be something wrong in the wire harness like one of the wire ties.
