Canon MFC 624 Constantly correcting
  • yormets
    • May 2009
    • 336
    I have this machine that will make one copy or print if turned off and on and then just constantly runs and says it's correcting. Other than installing OEM cartridges (no result) what can be done?
  • aAandy
    • Apr 2012
    • 370
    Re: Canon MFC 624 Constantly correcting
    you may have a high voltage board problem, or it could be a firmware issue - start with updating the firmware
    if that does nothing, check/clean the transfer belt sensors and while it's correcting, open the machine and look for calibration patches on the transfer belt, if one color is washed out, the machine will try to correct it by adding toner
    if you find one washed out, you could have a primary transfer problem (primary transfer roller in transfer belt assy) or HVT problems
