Canon Imagerunner 5020 part for corona transfer unit
  • canucktfi
    • Nov 2008
    • 9
    I recently serviced a IR5020. They had broken off the 2 electrical contact pins on the corona transfer unit. There are 2 posts that are at the back of this unit that mate with the copier's back panel. This part is only about 2"x2" and is screwed on (1 screw). The part is made of a resin/plastic material and broken (I will not attempt to glue this part due to the stress it takes during insertion/closing that slide). Can this part be purchased separately and from where?
  • 20YRSEXP
    • 281
    I believe you can get one but you need to buy one at an authorized canon dealer. I don't think anyone else can stock them.
    Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
    • mjarbar
      Hello,
      The part number is FH2-9246-000 (Connector, High Voltage) and should be available from your local Canon Authorised dealer.
