Canon IR Advance 6055 Trouble using scan and send via SMB
  • 813200217
    • Oct 2014
    • 51
    I have installed printer driver and already worked. (able to print using tcp/ip (network)
    But when i want to use scan and send using smb
    it keeps sending error
    "an error occured due to unknow reason
    anyone can help me?
    ps
    the other machine i have, ir 6075, i can use send and it succeed
  • roho
    • Mar 2009
    • 844
    Re: Canon IR Advance 6055 Trouble using scan and send via SMB
    Seems like you are following the right steps as far as I can tell. Print the TX report and you will get a error code #xxx. There is a PDF file that breaks down these codes as per sending to email or scanning to folder. Also will list some key matters to address for the particular problem. Google Canon send error codes for the PDF
    • guitar9199
      • Sep 2016
      • 1099
      Here you go...
        • 22801
        have you checked with their IT people to make sure the rights to the folder are SHARED?
        what is the OS on the PC's?
        have you upgraded FW in case of an SMB2/3 issue?
        have you tried to set it up to your laptop?
        • 813200217
          • Oct 2014
          • 51
          Thank you for you all reply
          I already succeed using scan and store via network
          there is a manual i try step by step
          first=
          Setting the Network - Canon imageRUNNER ADVANCE 6075/6065/6055 e-Manual
          second =
          Setting the Advanced Box - Canon imageRUNNER ADVANCE 6075/6065/6055 e-Manual
          the document i scan appeared on my network drive,
          i still don't understand why it succeed,
          "maybe SMB setting"
          • petermays
            • Mar 2017
            • 91
            hi..
            is user have a windows 10 OS
            A might have blocked your SMB1 port.
            you can check in run type
            windows powershell
            a blue screen will pop up
            at prompt type
            Get-SmbServerConfiguration
            look to see if EnableSMB1Protocol is on true
            if its a false then that pc smb port is blocked for scaning.
            you can unblock but dont.there is a special firmware for canon machines that open SMB2 FOR SCANNING
            If you working on a TA OR A KYOCERA then you will have to open port
            • guitar9199
              • Sep 2016
              • 1099
              If they're using Win 10, check the IPv4 adapter properties. Click "Advanced", and check the WINS tab. If it's set for "NetBIOS over DHCP", change it to "NetBIOS over TCP/IP". I've found that causes a bunch of scanning issues.
              You also need to check the Inbound Rules in Windows Firewall. Make sure all the "File and Printer Sharing" settings and the "Network Discovery (NB-Datagram) and (NB-Name) are ALSO set to allow. If they have a 3rd party firewall, you'll need to contact them to figure out how to configure it for SMB.
              If they have ANY instance of McAfee on their computer.... Good luck, you're going to need it!
