Control temperature fixing roller 165 deg C (standby)
Fixing belt (inlet roller) 95 deg C (standby)
Outside heating roller 200 deg C (standby)
Protective mechanism
A check is run for the following to cut power to the heater in the event of a fault.
check on the temperature using the main/sub thermistor
cutting the supply power using the thermal switch
Fixing roller TP1 (roller front end; contact; operating temperature of 180 +/- 7 deg C) Fixing belt TP2 (roller center; non-contact; operating temperature of 130 +/- 5 deg C) Outside heating roller TP3 (roller front end; contact; operating temperature of 220 +/- 8 deg C)
check for a thermistor open circuit/paper wrap
================================================== ================== WMUP1
(warm-up 1)
From when the power is turned on until the fixing roller surface temperature reaches 100 deg C. Thereafter, shifts to WMUP2. WMUP2
(warm-up 2)
Until the fixing belt surface temperature reaches 100 deg C. Thereafter, shifts to WMUP3. WMUP3
(warm-up 3)
Unit the fixing roller surface temperature reaches 160 deg C. Thereafter, shifts to WMUP4. WMUP4
(warm-up 4)
Until the fixing roller surface temperature reaches 160 deg C, the fixing belt surface temperature reaches 190 deg C, and the
outside heating roller surface temperature reaches 90 deg C. Thereafter, shifts to STBY.
STBY(standby) Ready for a print request signal.
<Control Temperature>
fixing roller surface temperature = 165 deg C/outside heating roller surface temperature = 200 deg C/fixing belt surface
temperature = 95 deg C
Operating environment
(temperature range)
15 to 27.5 deg C
(humidity range)
25% to 75 %RH
(atmospheric pressure)
810.6 to 1013.3 hpa (0.8 to 1.0 atm)
note: printer environment effects all durable (paper-toner-cq-drum etc.
1. If possible, check the planned site of installation before delivering the machine.
(1) The power supply main plug (back side of the main body), is rated as indicated and the power outlet can be connected exclusively to the machine, is 100V/
15A or more for 100V machine, 120V to 127V/15.1A or more for 120V machine, 220 to 240V/9.2 or more for 230V machine.
(2) The sub power supply (left side of the main body), rated as indicated and must be a power outlet that may used exclusively for the machine: 100 V/2.9 A or
more for more the 100 V machine; 120 to 127 V/2.6 A or more for the 120V machine; 220 to 240 V/1.3 A or more for the 230V machine.
(3) There must be a grounding terminal for the machine.
Targets of Grounding
(a) Grounding terminal of power outlet
(b) The grounding terminal finished to Category D Do not connect the grounding cord to the gas pipe.
2. Installation environment must be with in the following range. Avoid the close location to the faucet, water heater, humidifier or refrigerator.
Assured range of operation/image: temperature 15.0 to 30.0 deg C, humidity 5 to 80% 3. The area near the source of fire, place where dust gathers, place where ammonia gas generates, place exposed to the direct sunlight should be avoided. If the place
is exposed to the direct sunlight, it is better to hang a curtain in the window. 4. Although the ozone level generating in using this equipment does not affect human bodies, long-hours operation in a poorly-ventilated room may cause some
odor to be sensed. Ventilation should be done to keep a comfortable work environment. 5. The foot of the host machine should not get off the floor. The host machine should be kept in a horizontal status. 6. Allocate enough space for service operation of the host machine.
The drum heater control is activated by turning ON the environmental switch on the inside left side of the machine regardless of whether the main switch is turned
on or off.
Temperature control by the thermo-sensor (32 deg C/42 deg C) is possible by switching the drum temperature switch.
The timing of switching is determined by the absolute water level inside the machine. Memo:
Switch the drum temperature switch to the lower side ('H') for high-humidity environment.
Whether the environment is under high humidity or not is judged by the absolute water level inside the machine at service mode.
When the value of COPIER>DISPLAY>ANALOG>ABS-HUM is 10g or more.
Checking the Drum Temperature Switch
imagePRESS C1 (Printer) / imagePRESS C1 / imagePRESS C1+ (Printer) /
imagePRESS C1+
1) Set the drum temperature switch in accordance with the installation environment.
In the high humidity environment (*), set the drum temperature switch to the lower side (H).
* High humidity condition is a condition of which the value of absolute
humidity in a machine is 10 g or more.
Service mode > COPIER > DISPLAY > ANALOG > ABS-HUM
In a high humidity environment (*), set the drum temperature switch to the lower side ('H').
* High humidity environment is a condition in which the value of the absolute humidity (COPIER > DISPLAY > ANALOG > ABS-HUM) in
a machine in the service mode is more or equal to 10g. 2)Check the setting of 4-color/5-color model.
Service mode: COPIER > OPTION > BODY > CLCONFIG
- In case of 4-color model, make sure that this setting is set to "1".
- In case of 5-color model, make sure that this setting is set to "0".
3) After changing the setting, follow the shutdown sequence to turn off and
on power in order to enable the setting value.
