IR2520 - UST OR SST
  • MunsterTech
    • Sep 2014
    • 378
    [Misc] IR2520 - UST OR SST
    Hi guys n girls,
    bit lost here, customers IR2520 intermittently freezing, so decided to upgrade the firmware. Downloaded firmware from SIMS, but a bit confused of how to actually load it? looking in the service manual, it says use printer cable and SST, but when I tried upgrading, it was a self extracting file for the Main controller, which downloaded fine, but when I went to upgrade the DC it says this version is not useable on this Operating system, or something to that effect.
    Question, is there a specific UST to use for upgrading F/W or do I use the SST? Looking at the procedure in SM i plug in the USB printer cable, turn on the machine and the laptop detects a wizard, it says cancel wizard and open UST?
    HELP???
    • 16083
    Re: IR2520 - UST OR SST
    Bootrom, DCON and Main controller is flashed through Canon User Support Tool (UST).
    The Finisher controller PCB is flashed using Canon Service Support Tool (SST)
    Dropbox - UST_Operation_Guide_EN.pdf
