IC D1550 Stalls when scanning from document feeder.
  • rbazan
    • Dec 2013
    • 70
    [Misc] IC D1550 Stalls when scanning from document feeder.
    When scanning from D1550 to computer, it will feed 1st copy through doc feeder but the second copy will go in and stop- the D1550 "Processing" light will be blinking- the computer will show in a small window "Scanning" with a green bar 1/2 way- and it just stays like that.
    I have to shut D1550, remove the paper in doc feeder- then restart d1550.
    If I scan from the computer (which takes a bit of doing) ex. from start menu- Printers- right click d1550- properties- Start scan. It will scan all the pages.
    Couldn't figure out how to put a short cut on desk top for scanner so customer not happy.
    Summary:
    Using D1550 operation panel to scan to computer- will not scan multiple pages.
    Using computer to scan will work but requires to much manipulation.
    Any ideas appreciated. Thanks.
  • aAandy
    • Apr 2012
    • 370
    Re: IC D1550 Stalls when scanning from document feeder.
    Summary:
    have you tried a firmware update?
    • rbazan
      • Dec 2013
      • 70
      I didn't check for firmware update. I'll have to check what Canon has and what the machine has and try it.
